#205247 I was looking over the Hatch and looked over the damage again. It wasn't as Bad as I originally thought. Therefore me and my buddy decided on Fixing this rather then stripping it out.
Damage Door and Fender
And No More! I will be getting a replacement door, The Unibody damage isn't to bad. The Fender might be fixable, If not I will get a new one of those as well.
Swapped in a D16z6 with OBD2B Electronics.
After fixing the body damage, Will be respraying the Car. I have been thinking about Going Black. However probably will paint it EBP to match the rest of the car.
I was planning on putting in my DVD Player back into, GSR Leather Front and Rear Seats. and then building this up rather then my Sedan as I was originally planning on. 99-00 EK Hatches are much sexier then EG Sedans.
#205248 cool beans man.. tough gettin rid of a car huh??
cant wait to see this back in action :thumb:
By {ikon}EM1
#205293 Ahhhh yes good news :thumb:
I hope the rebirth of this ek is as exciting as the sol was... so what's the plan for this one??? R u going to do the VIP theam u were going to be doing on ur eg sedan with the ek??? hope the best for this car I really enjoy ek's...
#205429 I got a new Door! Picked it off Craigslist for $30! It was missing some things on it however.
Moved over the Keyless Lock Actuator to the New Door.
Moved the Key Lock Cylinder so my key works for all 3 doors as well as the starter.
Doing the above meant bending alot of the old door out, and I had to use a nibler to cut some of the old door apart as its so badly damaged. However the new door is currently in working order. Once I get and Install some glass and the Window up-down mechanism then I will install the Door.
94_jdm_ferio wrote:cool beans man.. tough gettin rid of a car huh??
Indeed it is hard getting rid off a car. I kept looking at it and just couldn't scrap it. Even if I was going to use it to make a VIP Sedan out of some of it.
{ikon}EM1 wrote:Ahhhh yes good news :thumb:
I do plan on making this a VIP Roller. I was originally planning on my Sedan however EK's hatch's are so much cooler then EG Sedans IMO. As much as I like my sedan, I couldn't cut up and scrap the EK Hatch to make it a VIP Sedan w/ 99-00 Front clip and dash. Having this all in an EK Makes so much more sense.
My Hope is to have this look just as good as it did before the wreck. The DVD Player is going back in. the Subs will be going in. I am trying to trade my EP3 Seats for some Leather RSX Seats. so I have leather all around.
blk92hb wrote:Another honda lives :woot: i cant wait to see this come back to life
Me Too! I'm Pumped to get this going.
Wedesday I should be headed back to the shop and getting the car ready to run. Expect an update on Wedesday Evening/Night.
BLaCkSiLo wrote:hell yeah man, glad to see you bring this car back, i always liked this car :thumb:
how was the support under the fender and anything else damaged since you took the door off?
I loved this car to, After looking at the front of again its hard to do anything but love it.
There isn't any really damage under the fender. Where the door latches is a different story.
D16z6's is in and running. Fully converted over to OBD2B
Around the front of the door the alignment is pretty good. Once I pop the dent out of the fender I will be putting that back on.
The Rear of the Door lines up vertically with the locking mechanism. However its pushed about 1"-1.5" Back. I'm contemplating have a body shop pull the post back into place.
By eg84dr
#206399 correct me if im wrong but isint it illeagel to put obd1 in an obd2 car?
i know you converted it but how?
like what did u have to change ?
how did you ad a knock sensor and such
good work btw on restoring a honda that was looking at a junkyard life haha :thumb:
eg84dr wrote:correct me if im wrong but isint it illeagel to put obd1 in an obd2 car?
Its not legal to put an older engine into a newer car. However, the Engine is fully OBD2B.
I took all of the OBD1 Electronics out of the D16z6 Distributor, then Installed OBD2B Electronics in it. I installed OBD2b Fuel Injectors, and an OBD2b B Series Alternator. I wired it back into the EM1 OBD2b Civic Si B16 Wiring Harness. Its currently being run by an OBD1 P28 ECU w/ an OBD2b to OBD1 Jumper Harness.
I look forward to having this hatch look just like it use to before the wreck.
By d-mon
#206428
are you going to do anything about the knock sensor? then you could run a p2p ecu for inspections (if necessary)
i put a z6 into my 97 coupe, with an obd2a EX harness, but spliced injector clips for obd1, and iat with a p28 ecu.
#208531 I worked on the hatch agian. I got the door to seal and shut.
The Hatch is now sitting in my Garage next to the Sol, Waiting for the 18th. JustinleeXXX will be back in Town and help me finish off the body work. Then bust out the Spray gun to repaint everything Electron Blue Pearl.
eg_turbo_hatch wrote:any updates?
I'm moving this week to my new house which doesn't have a crazy home owner assocation. There is where the hatch sits waiting for me to finish the move. once moved in, I will finish the body work, prep for paint then bust out my new Spray gun. There will be lots of updates in about a week.
#211028 Hatch is at the new house, So I Did some body work today. Pulled the dent out and almost ready for bondo. Next update should be late Wednesday.
Things left to do:
Pull dent on fender
Bondo fender, door, and 1/4 panal
Get CTR poly Lip
Prep for Paint
Repaint Electon Blue Pearl
Get Random OEM Honda Rims, Probally webs
Slam on Ebay Coils + Oem Struts
Reinstall interior
