By JDMsol91 - Fri Jan 16, 2009 10:25 am
#89414
------------------------------------------- Vehicle history ----------------------------------------------
Buy date : Saturday 05 july 2008 !!!
Buy kilomeage : 116000km
Way of purchase : Rouen --> St Etienne (about 700km)
Negative points :
* some pocs and stripes on the body,
* a tear on the conducting seat on the reinforcement on the level of conducting door,
* a light cigarette burn on the momentary seat on the level of before base.
----------------------------------------------- Data sheet --------------------------------------------------
Make : Honda
Type : Civic CRX (CR-X Del Sol) EH6
Model : 1.6 ESi SOHC VTEC - Special & limited series "25th Birthday Honda"
Motor and gearbox type : D16Y8 SOHC VTEC motor with S8G gearbox
Exterior color : Vogue Silver Metallic
Interior finish & color : Red Leather
Equipements : Airbag driver, ABS, Power steering, Aluminium wheels 14 inch, Front & rear brake disc, power antenna, power windows, power doors lock, manual hard-top.
Accessories : AM/FM/Cassette autoradio Pionner + CD-changer 6CD Pionner (purchase of origin with the vehicle, posed in concession)
Putting into circulation : 01/07/1997
Actual kilomeage : 123500km
-------------------------------------------- List of project's modification ----------------------------------------------
budget of the project : 25.000€ = about $33,000
Exterior :
- JDM EG2 CR-X Del Sol SiR Headlights (33100-SR2-J03) Built
- JDM EG2 CR-X Del Sol SiR Lower Fog Lamps w/switch (08V31-SR2-600)
- JDM EG2 CR-X Del Sol SiR front bumper, front fenders (left and right), hood Built
- Tein Hood Damper (#BHD01-H26) WTB
- JDM EG2 CR-X Del Sol SiR Side Marking Lamps (33800-SR3-J01 / 33850-SR3-J01) Built
- JDM EG2 CR-X Del Sol SiR Side Decals Grey (DOHC - 75772-SR2-003ZF) WTB
- JDM EG2 CR-X Del Sol SiR Side Decals Grey (VTEC - 75774-SR2-003ZF) WTB
- JDM EG2 CR-X Del Sol SiR Mud Guards Built
- JDM EG2 CR-X Del Sol SiR rear bumper Not Built
- JDM EG2 CR-X Del Sol SiR Taillights Not Built
- JDM EG2 CR-X Del Sol SiR License Plate Filler Panels Built
- JDM EG2 CR-X Del Sol SiR Rear Badge Grey (CR-X Del Sol - 75765-SR2-J02ZF) Built
- JDM EG2 CR-X Del Sol SiR Rear Badge Grey (SiR - 75723-SR2-J12ZF) Built
- MUGEN Rear Wing CR-X Del Sol EG2 (Replica) WTB
Chassis :
- Password:JDM 3 Point Front Strut Tower Bar Built
- Password:JDM 2 Point Rear Strut Tower Bar Built
- Tein Super Street Damper Adjustable Coilover Kit Built
- Honda Genuine OEM uppermounts Built
- A-Spec Racing rear subframe brace blue exclusive limited edition by Weksos Industries
- Function 7 rear lower control arms V3
- Supension Techniques front & rear 19mm anti sway bar kit (#52161)
- Blox front & rear camber kit
- Energy Suspension Hyperflex Master Bushing Kit (Red - #1618103)
- Cusco front lower bar (blue color)
- Beaks reat lower bar (gold color)
Motor :
- RC Engineering 750cc Fuel Injectors
- AEM High Volume Fuel Rail
- AEM High Volume Fuel Filter
- AEM Tru-Time Cam Gear
- B&M fuel pressure regulator
- B&M fuel pressure gauge
- MSD red distributor cap (82921)
- MSD red blaster 2 performance coil kit (8203)
- NOLOGY Hot blue Ignition Wire
- NGK Blue Iridium Spark Plugs
- Edelbrock Performance X Intake Manifold polished finish
- Hondata Intake Gasket
- Walbro 255lph fuel pump
- ZEX comp camshaft (103500)
- Supertech valve springs (SPR-H1002S)
- Supertech titanium retainers (RET-H1002/T1)
- Supertech black nitride race valves (HIVN-1012, HEVN-1012
- Cometic MLS head gasket 75mm bore & .030" (COMH1469SP2030S)
- ARP head stud kit (208-4305)
- Supertech block guard (BG-D15/D16)
- CP piston 75mm 9.0:1 (SC7050)
- Crower I-Beam 4340 billet connecting rods (B93745B-4)
- ACL Premium bearing standard size (5M1957H, 1T1957)
- Garrett GT2860RS/GT28RS Disco Potato turbocharger (739548-1)
- FULL RACE D Series ProStreet Stage 1 GT :
--- Full-Race T3 ProStreet Manifold
--- Full-Race 3" 4-bolt Downpipe
--- Full-Race Intercooler
--- Full-Race GT28RS Ball Bearing Turbo
--- Tial 44mm Wastegate
--- Tial 50mm Blow Off Valve
--- Full-Race Intercooler Piping
--- Full-Race Oil Line Kit
--- Full-Race Vacuum Line Kit
--- Full-Race Hardware Kit
--- Full-Race Gasket Kit
--- Full-Race Silicon Coupler Kit
--- Full-Race Hose Clamp Kit
- Boomslang OBD conversion (harnesses)
- Hondata S300 on P28 ECU with VTEC at 4500rpm and Ruptor at 8000rpm
- Innovate LC1 O2 wideband
- Invidia N1 Full Inox Catback exhaust Built
- Password:JDM shifter bushings
- Innovative engine mounts
- Password:JDM Carbon Kevlar PowerChamber Intake Built
- JDM Hamp Oil Filter
- JDM CTR N1 Crank Pulley
- Fluidyne Performance aluminum radiator
- Flex-A-Lite red slim line fan
- Password:JDM Kevlar Cooling Plate (EK '96-'00 Civic)
- ACT Xtreme Clutch Kit ref: HC5-XTSS
- Exedy Lightweight Racing Flywheel. Part Number: HF501
Wheels & Tires :
- Muteki SR35 Lug Nuts – Neo Chrome (Open Ended)
- Spun KR-206 Black w/ red lip 4x100 ET40 Rims Built
- Toyo Proxes T1R 195/50-R15 82V Tires Built
Interior :
- Personal Grinta 330mm Black Leather / Red Stitch Steering Wheel
- Works Bell Rapfix II Limited Edition Orange Quick Release
- Spoon Duracon Shift Knob Bought
- JDM Road Flare and Mounting Bracket
- JDM EG2 CR-X Del Sol SiR Map Lights (34230-SR2-013ZA / 34235-SR2-013ZA) Built
- JDM EG2 CR-X Del Sol SiR Gathers Rear Speaker Grills Built
- JDM EG2 CR-X Del Sol SiR floormats (08P14-SR2-060 / 08P16-SR2-A10) Built
ICE :
- Alpine CDA-7998R Head Unit
- JL Audio SB-H-DELSOL/8W6 Stealthbox
- JDM EG2 CR-X Del Sol SiR Gathers Speaker System WTB
Caption : Built, Not Built, Bought, Want To Buy.
I SPECIFY, TOPIC AND LIST UNDER CONSTRUCTION, THANKS ALL
Negative points :
Make : Honda
Exterior :
Chassis :
Motor :
Wheels & Tires :
Interior :
ICE :
