- Fri Jun 03, 2016 3:44 am
#359226
all together, spacing perfect ..... you will also realize in the pics i have installed the slave cylinder and steel braided clutch line. i put the rubber boot over it when i was done
- Fri Jun 03, 2016 3:46 am
#359227
bought 2 fans to be used on the AC core.. i want the north pole up in there
also picked up a set of horns
- Sat Jun 04, 2016 12:25 am
#359234
hail peeps... alot of progress made today, mechanic was there bright and early and spent the day
uploading pics... will post later and also tell you plans for tomorrow
- Sat Jun 04, 2016 11:48 am
#359240
the following hoses will be replaced with steel braided lines. just used these temporarily to get the car wired and started.
- the hose running from the booster to the intake manifold
hardline and hose connected to the fuel rail
