- Sun Apr 07, 2013 1:08 pm
#330199
I might sell it, because its not compatible with my incoming Cruise Control retrofit
Whats new here?
Well, I bought a complete JDM Auto Climate Control retrofit.
All I can say is that its far from plug and play.
I started the retrofit from cleaning the rusted brackets in CRC-rust remover. Part in the picture is outside temp sensor bracket:
Then i swapped the manual climate main harness to automatic (dont mind the other wires, i needed to unwrap them because they were tied together with manual harness:
Here goes the heater core temp sensor:
When the main harness and the heater core temp sensor was installed, i choosed to remove the blower resistor. The new mosfet thingy wasnt plug and play, so modifications needed, again..:
Next thing: Airmix motor modification:
Then i noticed that any of the parts suplied wont fit to LHD heaterbox. They arent even mirrored, they are completely different. So, custom work needed:
You could add a big questionmark to this picture:
Couple problems: How to connect the air mix motor to cable actuated links?
I thought that i will do my own link and bracket to the air mix motor.
3,5 hours of pure testing and measuring. One millimeter wrong and the motion path wasnt full. Wasnt really too nice to spent that time under the glovebox.
Prototype:
How i did the custom bracket to air mix motor:
I used modified cable actuated versions plastic cover as a template. Wasnt really the easiest job, but i managed to find out where the motor needs to be installed to achieve perfect operation.
And my custom bracket:
Main harness:
Blower relay:
Rust free bracket:
Installed:
Sunbeam sensor:
I installed it to this vent, cause I´m changing the dashboard some day. Then i will install it to its OEM-location.
Then i needed to add this inside temp vacuum thingy :s
And the airmix motor installed correctly
Stay tuned for future updates
