- Sat Dec 10, 2016 7:12 am
#361066
What's up guys,
So I picked up a little somethin' somethin' the other day
Got this engine lift kit from EliJoe_Low on Instagram for $85 shipped. I went to S&S Exhaust and had them weld it in for $40. It's supposed to lift the engine 1" closer to the hood as well as improve the steering rack and driveshaft angles, and the results are great! Here are some pics:
Here's the kit. It comes with two new bolts for the side motor mounts as well as spacers for the rear mount. The two torque mounts on trans and power steering pully bracket need to be removed for this kit to work.
this is what the new mounts look like all welded up. Not the prettiest, but they'll do just fine. You can see how the new bolt hole is around an inch higher than the old one.
as you guys know, the rear motor mount and it has 3 bolts which attach it to the subframe. The spacers pictured above will keep it from binding when the other two mounts are raised.
Along with the spacers, I had to run out and get these new bolts which are twice as long as the stock ones so that I can still have a good amount of thread going into the subframe.
It started getting dark at this point and I got more into the work, so I forgot to take pictures. Rest assured that the kit did the job well and I no longer scrape exhaust!
But I'm still scraping the front sway bar sometimes so that's coming off next lol
A couple weeks ago I picked up this rear disc brake conversion from an integra for a whopping $20 lol. I just need to find some e-brake cables from a teg so I can swap them in.
Next items on the list are:
1) drop forks (for more strut travel + more low)
2) rear fog light
3) alignment
4) camber???
5) idk lol
93 EG8 D15B7
My Build Thread:
viewtopic.php?f=61&t=28131Instagram: @Stance_God
