- Sat Nov 03, 2012 4:55 am
#319110
ok EH2_andy, i think your diagram may have helped i got to looking at STOCK set ups and realized with a stock intake setup instead of the little filter on the valve cover you have the lines...
the red in the image represents the lines i dont have, the green hose is what i believe to be the hose dangling right now, and the green circle is what i believe to be the nipple i have thats open, would that make sense? or am i wrong about that...i just dont see how i could get them to connect if i were correct.
EDIT: i will try tomorrow to get more detailed pic where the hose comes from but i belive this is the solution, i have to work from 9-6pm tomorrow so it may be dark before i get home...if you can take some pics of your set up with the simillar lines mentioned i can go from there, but what i found on google seemed to be pretty conclusive to this, unless im competely retarded...i hope i made that as clear as possible
thanks again for your time and advice
