- Sun Sep 12, 2010 6:05 am
#213220
Man its been a while since i have been on here. Few updates for ya and hopefully pics soon. I got rid of all my ebay shit finally and slowly getting shit done. Problems still never ending
RC autoworks mini ram manifold and turbonetics 38mm wastegate, still ebay turbo at this point.
Ran 25 psi and 274whp 234tq, was fun for a few months, then no boost over 13psi no boost leaks or anything, came to conclusion it was turbo.
Garrett 60trim came in, 309whp 240tq on 26psi. Thought numbers seemed low still. But fuck it right, thing moved out, did bunch of pulls on the dyno all day, took it home, did two pulls, no boost over 12psi. WTF!?
New tial 50mm bov going on and 2.5 or 3 inch ic piping instead of my 2 inch i have now. Hoping will gain some on that, but everything else seems in tact that should be for it to make 26psi. Compression is good oil pressure is good little to no blow by, tune is good, map sensor is working 4bar, no leaks anywhere. Pulled valve cover off valve lash real loose, pulled cam, exhaust lobes are like falling apart, its all chipped away. Assuming thats what is causing the boost issue, got rid of the shitty crower stage 2 cam. My Bisimoto level 3.6 just came in yesterday.
I will keep you updated on what happens with the new cam and maybe get some good numbers.
