- Tue Feb 02, 2010 6:00 am
#172627
City lights : well here we go
i got a stock set of headlights and some of these ..
This is a Add to the city light thread , just puttin alittle of my input on this subject, Its basically the same, Just throwing out a couple more ideas ..
I Used sockets from the tailight harness that I had spare such as these.
Then instead of drilling on that little circle right next to the bracket (See Pic) on the inside I went over here (Red 'X") for the extra clearence and now worries or trimming the socket later.
Then with the 1/2" Bit i drilled right on the "X"
Cant even see the socket. Nice for Clearence
Bulb way over in the housing
Made alittle notch to turn and Lock ( I did cut 2 of the three notches off the socket)
bulbs in and locked
I also used amber bulbs for the match of the corners (Installed)These pic are in the middle of the day.
Just to let you know as the City light DiY states basically: These dont project light just iluminate the headlight housing and glass . kinda like another marker light, so your seen easier and what not .
I should also reference that I spliced into my foglight harness so i can infact turn them off . just to throw the idea out there.
Let me know what you think
