By kylenjdm93
#325644 the rule of thumb were i come from is....
daily driver = reliable, NA all the way
weekend warrior = NA, mild turbo set up low boost, supercharger
drag car = high boost high dollar build. either supercharge or turbo
im all about the daily with weekend warrior feel so im definately keeping my k all motor with eye candy :thumb:
kylenjdm93 wrote:the rule of thumb were i come from is....
Nice way to put it! :thumb:
By Fada Blayne
#325715 Full H swap for the win!
Cams,Intake,Headers and a good tune and you'll be at 220whp easy!
By kylenjdm93
#325723 hey thats my k20a r stock... lol
imagine what my cams, header, intake, pistons, valves, and krpo will do...
alot of guys run the h2b to combat kswaps, the power of the h22 with the gear ratio of the b is a deadly mixture.....
the d series trannys are way to slow for me, too long of gears
but i have ridden in a ek h22a mildly built and it hauled some serious ass :thumb:
im excited to see the outcome!
By Fada Blayne
#325736 There is alot more to having a fast car than whp, I'm sure you know this Kyle :)
#332202 Have not updated in awhile. So here are some lil updates.
#332204 Got a oem exhaust shield, painted it and splattered a lil purple on it. Also got a Cusco front plate re-locator.
#332205 Also got new exhaust piping done since my old piping was 19 years and I couldn't go any lower because pipe would hit my lca.
:lol:
new piping 2 1/4. i love the new flow. lol :D
Old 19 Year old piping....LoL
Muffler Fixed and aligned right. :THUMBS:
#332207 The piping was done a couple months ago and when doing it, I noticed that my bolts from my sway were gone so I got new hardware.
#332209 Also about two three months ago, I ended up helping a kid who had been trying to sell his Coupe. Had alot of work that it needed done. Here are a couple pics of stuff I did and stuff it needed.
He got screwed over by someone his parents knew. He got his Honda Stolen last year and then this guy sold him a Coupe that needed a lot of help. But he didn't know that, buying and then trying to sell it this past month.It needed a new starter,idle adjusted, new battery tray,new thermostat housing, thermostat (cause it didn't have one and housing was covered in RTV sealant all the way around,housing bolt was broke in there), fast idle thermo valve nipple was broke off,water tube was leaking and needed to be replaced and the seals as well, valve cover gasket and tube seals needed replacing, dizzy o ring. And its still needs the T-Belt,tensioner and water pump replaced. Oh and the suspension is horrible, ebay coils on stock struts with the coils just sitting there with no rubber grommets holding them in place. I felt bad for the kid and the Poor Ol Coupe.
The Battery Acid ate all the paint...
Old Rusty Battery Tray. Replaced and Battery Tray plastic and battery holder Added.
The Thermostat Housing super corroded,water tube and rubber o-ring. All replaced.
Sanded down, applied rust remover,convertor and protector, then paint. came out ok.
His Coupe and Mine
#332210 Well haven't gotten to the Rear Brakes yet but will. Changed my exhaust mani to another Y8 manifold. Will post pics later and I did do something that needed to get done. I got my Replacement Kontrol Pro shock from K-Sport and redid my coilover. Will be doing a DIY on this. Will be more pics on the DIY Thread.
Replacement Shock
Old leaking shock... (LOL I bent the little allen wrench, poor little guy)
Done and compressed and had to play with the height just a tad after I put it back in. ;)
#332211 At the begining of the month I ended up getting another set of BBS Ra's, not as clean as my old set. I ended selling them.. :lol:
#332212 And I got these!!!! Can anyone Guess!!??
:D
By Fada Blayne
#332277 RacingHarts?
