By BLaCkSiLo
#207519 so i got friskey and decided to pull out most of my dash cause it was rattling and i wanted to replace the cup holder, i replaced my burnt climate bulbs with white LEDs and glued/screwed the bezel back into place cause all the mounts were broken.
new cups (local junkyard) one out of a sable and one a taurus.
on a side note: been playing with these lately (mine is left and buddys is right, but broken right here, fixed her all up real fast)
By andyc
#207989 Hey buddy, first of all - great purple coupe :thumb: its very similar to where I want to take mine. I wanted to ask, your recent issue with starting, on the occasions that it wouldnt start did the engine turn over properly, or spark?? My coupe has been undrivable for weeks as Im tryin to get a new dizzy, but if it could also be the starter I might be barking up the wrong tree?? Mine turns over fully and fast just doesent spark to life??
just wandered... :D
By BLaCkSiLo
#208111
ANDYC wrote:Hey buddy, first of all - great purple coupe :thumb: its very similar to where I want to take mine. I wanted to ask, your recent issue with starting, on the occasions that it wouldnt start did the engine turn over properly, or spark?? My coupe has been undrivable for weeks as Im tryin to get a new dizzy, but if it could also be the starter I might be barking up the wrong tree?? Mine turns over fully and fast just doesent spark to life??
just wandered... :D
hello andy, my car in this particular case when it wasent starting, it was the ignition "pos 3" start was not engaging because of the extensive heat and cause everything to happen except for telling the starter to turn over.
in your case where it cranks and doesnt fire, does it happen when it's hot and does it do it all the time or some of the time? I almost bet it's your main relay, because it doesnt send power to the fuel pump sometimes which makes it crank and not fire....hope it helps man! :thumb:
By andyc
#208127 its definetely gettin fuel buddy, just no spark... Im gettin a dizzy from a mate at the weekend which should do it, I was just thinking... imagine if it was something else :lol:
The relays click, fuel pumps whirs, engine turns over, just dosent spark to life :x Im sure the dizzy will do it, well see eh
cheers mate :thumb:
By BLaCkSiLo
#210104
ANDYC wrote:its definetely gettin fuel buddy, just no spark... Im gettin a dizzy from a mate at the weekend which should do it, I was just thinking... imagine if it was something else :lol:
cheers mate :thumb:
did you ever get your situation figured out? hopefully it was just the ignitor in the dizzy...
*update*
so i finally got a job working as a full time mechanical engineer so i hope to have more updates to come but this is what i have been doing for a majority of the time: :bigok:
and thought this was funny:
By andyc
#210146 haha nice... No mate my cars still buggered, I got a new dizzy (well used but apparantly working) fitted that and nothin :cry: I need to sort the IAT code out and see if that does anything. if not i might just get a hatch, i been feelin a white hatch coming on for a while :D
#210265 Congrats on getting full time work. :thumb:
Also good to seeing your boosting often.
I'm looking forward to your new updates. :thumb: :thumb:
#216266 updated this bishhh now son!!!
how is the coupe man??
#216291 I like those Coin/cup holders. I will need some soon enough.
By BLaCkSiLo
#216306
chrono404 wrote:Congrats on getting full time work. :thumb:
thanks man! yeah i boost quite often, like everyday/everytime i drive it :thumb: it's good having a job, minus the student loans!! how's the house?
94_jdm_ferio wrote:updated this bishhh now son!!!
It's doing pretty good man, i have been driving the SHIT out of it! like 50-70 miles a day :shock: how's your sedan?
Greasedmonkey wrote:I like those Coin/cup holders. I will need some soon enough.
thanks man, i got them free at the local Boring junkyard :thumb: one out of a 92-95 sable and the other a Taurus. had plently on the lot.
UPDATE!
so this is how my car was sitting last wednesday/thursday night:
i replaced BOTH rear brake calipers because the one i got about a year back was defective and the other one was OLLLD. however, i got one for free from autozone through some warranty loophole and the guys totally helped me out!
Left:
Right:
damn, they feel so good now, plus my ebrake works great which is why i did this to begin with....to go to the track on friday night.
so on my way home i notice this after i shut it off and about 10 min went by:
on my fucking way to the track!! I park for about 2 minutes and this much oil leaks out...and i just changed my oil...FML
so needless to say i didn't go to the track because saturday night i boozed :lol:
Familiar Sight:
after doing some looking around, even buying a rear main seal cause i thought it was that but ended up being the oil pan gasket :(
as you can tell, it's cracked right down the middle...anybody else have this happen?
so i got it fixed and it don't leak at all, put some loctite on the bolts/studs as well.. got a few other leaks that i hopefully sealed up the other night.
one other thing, my tranny side motor mount bolts decided to leave the building so i got some NAPA specials lol: (the bright red ones)
I'm working on getting some different lowering springs right now, i got 2 front H&R sports, i need some rears. suspension, resonator then a wastegate (maybe) are in the future...
the sedan is good man, you should go check it out 8)
Loving the new house. I hate moving but you gotta do what you gotta do. My Sedans waterpump is pretty dead, Been dying a while however its leaking tons of water now. Going to be breaking in the Garage doing a swap for it soon. Until then its Daily Driving Del20 time.
Sucks about your Oil Leaks. Its crazy the gasket would break like that. I'm glad you got it fixed.
By BLaCkSiLo
#216817
you have made quite some good progress my friend 8)
oh man, did/does the waterpump make any noise? i had one lose a bearing on my old 460, she was squealing bad!
good to see your going to break-in the new garage with a swap, what are you swapping, the z6 out?
i can't believe my luck sometimes with the leaks :lol: but it will get better, i plan on picking up some rear H&R sport springs tonight, then get a resonator to quiet things down and we will be in business :thumb:
how's life going?
how's life going?
Theres a d15b7 in there currently. Its water pump has been squealing the whole time I had it. However it drove and didn't really bug me. Just add some water every two weeks or so, then every week, then every few days then it got to the point where its pretty much undrivable.
I wanna build my Z6 outta the Delsol and put it in the Sedan. At the very least I want to put new Rings into it as it smoked when I pulled it out of the sol. New Waterpump, Oil Pump and Timing Belt so I wont have these issues in the Future. Then maybe lay some paint in the bay and put in a much freshier engine to shuttle back and forth to work.
Im glad to see your getting new springs, Make your coupe more daily driving friendly. Thats will life easier.Daily Driving the Stiff Suspensioned Delsol Daily makes me look forward going back to my Sedan for Daily Driving Dutys.
Quite exhaust is also always a good thing. Loud exhaust is fun for short periods of time. But it gets old. If you have a little deep burble/grunt thats perfect IMO. Sounds like your on the correct path for it.
Life isn't to bad. Cant complain to much. I Found out that Body work is much easier then I figured it would be. Come Payday I will be getting some Electron Blue Pearl and painting the Hatch. I'm pretty pumped for that. If it turns out good the Blue Sedan is also Going Electron Blue Pearl but with a Gold Bay.
I remember you wanted to Paint your Coupe Electron Blue Pearl back in the day. If thats something your still wanting to do I can paint your coupe for you as long as you get the materials and paint. If thats something you want to do it will take a while for the paint and clear to dry. but if you come up in the morning hopefully by evening the clear will be dry enough to drive home with.
By BLaCkSiLo
#217347
chrono404 wrote:Theres a d15b7 in there currently. Its water pump has been squealing the whole time I had it. However it drove and didn't really bug me. Just add some water every two weeks or so, then every week, then every few days then it got to the point where its pretty much undrivable.
oh man, lame about the water pump.. was it just leaking around the housing and spewing water everywhere underneath?
i think building the z6 is a good choice, i don't regret it and i'm HARD on it, boost it every day, she runs strong! stock head too... :lol:
new rings will give it a boost no matter what plus no smoke.
i agree with you on the springs, however my tires are still really low-pro and are not forgiving. i'm looking at getting a set of 16's..i Really like the ones you have on your sedan (the white ones). i was thinking of fixing up a set off of craigs
i'm working on that resonator soon. dude that sounds like a fantastic idea, the only problem is that i have probably 10-20 hours of body work i need to do before paint. i could probably do that and then drive up, it would be a weekend correct? how much are we looking at for supplies and paint? when did you plan on painting yours?
