- Mon Mar 13, 2017 2:24 am
#361349
well, i got pretty far today, only thing left is to fix a few wiring issues...
managed so far to do:
-install radiator
-replace bypass hose
- install new thermo-cylinder head hose
-replace with new coolant temp sensor
-fix axle since it wasnt all the way in
-gap and install NGK spark plugs
-install spark wires
-install and seal up valve cover gasket
-add oil, add tranny oil, add coolant
-install cluster and wires
-cut wires and install new terminals for battery
-mock up header
-cover up and replace all the block off valves and locations on manifold
-replace a few clamps
-install fuel rail and plug up fuel filter
not much pictures, i actually took a bunch of pictures of the wires so i can look it over at work and try and figure out why my car isnt starting...well..to be more descriptive...no fuel being sent to motor, no spark, and no crank...but the lights all work and CEL is up...
if anyone can pitch in, let me know...im running out of ideas...gonna post a thread up in the B series side of the forums to find some light
