- Thu Feb 14, 2008 5:59 pm
#42298
Bouli wrote:hmm that's tricky, but i can make it work
The highbeam is has a H1 bulb ?
the highbeam is an H1 bulb.. it's not really that bright compared to the HIDs. I was initially going to just wire them to a foglight switch and run them as fogs. I slapped yellow bulbs in there as the ricer i am
you need a wiring harness to keep the HIDs on when you pull the highbeam..
This allows for:
Parking lights off: highbeams can be flashed without hid beams turning on as well.
Parking lights on: high beams can be flashed and when you pull the highbeams to stay on, it will not turn off HID beams.
H4 turns off the lowbeam when you put it into the highbeam position so you ahve rewiring like above so it doesnt turn off the HIDs.
-LowTEC Derbo "the coupe" Build Thread
http://civic-eg.com/viewtopic.php?t=1589
272whp 214wtq
