- Wed Jun 25, 2014 9:04 pm
#346748
Looking at buying some turbo pistons and thought seeing as the block I'm building needs honing anyway why not go for bigger pistons so my first thought was 82mm nice not to big but enough for a stable setup.
After speaking with a friend he's said that if I go above 81.5mm bore I should sleeve my block, would I be able to run 82mm pistons without sleeving my block.
My power target is only 280whp on a B16a2 but want it low boost and safe
