#26 If you're going turbo, you're going to need bigger injectors for lots of boost.
I used DSM 450cc and they did not fit quite right... they were bigger and did not go in as far:
this prevented the fuel rail from going on all the way
There's a couple ways to remedy this...
You can either dremel out the hole in the rubber insulator to help the injector sink down a little further. Like grinding out the hole in a donut to make it bigger.
Or you can cut the insulator in half, like you would cut a bagel.
I'm gonna go eat breakfast now :mrgreen:
By eghatch
#132 or if you have enough space to still thread on a nut. then you just put a spacer where the gap is... thats what ive always done for taller injectors..
By decepticon
#201 hey im doing this to mine... but mine were already made for putting in... nice pix
By chnzgoofball
#2155 awww... wish i knew this when i was doing turbo... i bored my injector rings bigger to fit took me hella long to do all 4 hahaha
