- Mon Jul 08, 2013 9:25 am
#333987
thought it start getting parts out the house as theres no space for it to lie around (headliner etc takes up alot of room lol)
put the rear harness back into the car, got the boot latch connected up, glass is in and mounted the spoon duckbill
then finished up wrapping the liner and installed that
put the bonnet on just so its out the way, ill remove it when i work in the bay
- Mon Jul 22, 2013 10:23 am
#334542
pretty productive weekend, a good mate of mine came passed to lend a hand so things went alot quicker
My sedan used to be carb, but converted it to obd2a to use the ITR ecu that came with the motor. this was a mission to wire in most things individually, so this time i decided to install the SR4 180i harness (OBD1) then get a jumper harness (with added Knock sensor) from obd1 to obd2a to match the P73 ecu.
Luckily for me, the ITR engine harness can be plugged directly into an obd1 harness as its a 2 piece design where as a ek4 uses a 1 piece design.
Found out how expensive a jumper harness is thanks to our exchange rate ($200 for a bit of wiring) soooo a friend offered to help me out making 1
started off comparing the plugs currently running into my ecu, then confirmed that i can indeed plug the ITR engine harness into the SR4 harness
some repairs and alterations done
got the harness in
Next i grabbed a spare ecu i had lying around (b18b obd1)
Soldered the pins out
salvaged obd2a plugs from a ek4 harness
got the harness in
- Mon Jul 22, 2013 10:27 am
#334543
also converted the car to FI, seems the car might have had evap, extra line run to the carb tank, which means a bigger 6mm return so no need to change hard lines
Old rusty tank out
New dusty tank
fuel pump looked old so changed that out for 1 i forgot i had in a box (b16 pump)
Old
New - er
tanks in, connected
Just need to grab a oem fuel pump plug i have somewhere
saturdays mess
Removed the front brake assembly
Wheel bearings, ball joints and Integra Type R calipers, disks and EBC red stuff pads to be retro fitted
ITR front sway to go in next
Old rusty tank out
New dusty tank
Old
New - er
tanks in, connected
saturdays mess
- Wed Jul 24, 2013 3:44 am
#334637
That color is incredible! Amazing work on your EG. Carbon fibre blends well with your choiceof color.
- Wed Jul 24, 2013 12:00 pm
#334652
i was about to post the same exact thing
AutoXRacer wrote:That color is incredible! Amazing work on your EG. Carbon fibre blends well with your choiceof color.
2007 Honda Civic Si
- Wed Jul 24, 2013 1:03 pm
#334655
Thanks!! i spent a few sleepless nights thinking about the color scheme i want, i think ill try source some matte black slips or Mugen RNRs in white
the cf bonnet i purchased without seeing it first.... which wasnt smart. it fits really bad. going to try get it aligned after the cars running
@ AutoXRacer, can't believe you bought ur hatch for $50!
- Wed Jul 24, 2013 2:25 pm
#334659
awesome work put in your project Dean, some real dedication bra, Black slips will look siiick just make sure they are 16" ne lol and here is a guy in Cape Town selling Mugen RNR reps in white keep up the awesme work buddy
DeanPant wrote:Thanks!! i spent a few sleepless nights thinking about the color scheme i want, i think ill try source some matte black slips or Mugen RNRs in white
Current: EG Sedan 180i
ex:96 EG Sedan 180e
ex:95 EG Sedan 180i
ex:95 EG Sedan 180i (SA spec)
ex:96 EG Sedan 180e
ex:95 EG Sedan 180i
- Tue Aug 06, 2013 7:48 am
#335181
Update : Been busy putting everything back in, only really have time after work in the evenings.
wiring is all in, dash and air boxes, fuse box under the dash, DC2 brake booster and master clutch cyl
Completed the Jumper harness this past sunday with a friend
heres a the pin outs that were needed
OBD-2a || OBD-1
A01 - INJ #4 || A02 - INJ #4
A02 - INJ #3 || A05 - INJ #3
A03 - INJ #2 || A03 - INJ #2
A04 - INJ #1 || A01 - INJ #1
A05 - EMPTY
A06 - PO2SHTC || A06 - PO2SHTC
A07 - EMPTY
A08 - VTEC || A04 - VTEC
A09 - LG1 || A26 - LG1
A10 - PG1 || A23 - PG1
A11 - IGP1 || B01 - IGP1
A12 - IACV || A09 - IACV
A13 - EMPTY
A14 - EMPTY
A15 - EMPTY
A16 - FLR Fuel|| A07 - FLR
A17 - A/C Ctrl|| A15 - A/C Ctrl
A18 - MIL || A13 - MIL
A19 - ALTC || A16 - ALTC
A20 - ICM || A21 - ICM
A21 - EMPTY
A22 - LG2 || B02 - LG2
A23 - PG2 || A24 - PG2
A24 - IGP2 || A25 - IGP2
A25 - EMPTY
A26 - EMPTY
A27 - FANC || A12 - FANC
A28 - EMPTY ||
A29 - EMPTY ||
A30 - EMPTY ||
A31 - EMPTY ||
A32 - EMPTY ||
C01 - EMPTY
C02 - CKP P-side || B15 - CKP P-side
C03 - TDC P-side || B13 - TDC P-side
C04 - CYP P-side || B11 - CYP P-side
C05 - A/C switch || B05 - A/C switch
C06 - STS || B09 - STS
C07 - SCS || D04 - SCS
C08 - K-line || D07 - Diagnostic
C09 - EMPTY
C10 - Volt/backup|| D01 - Volt/backup
C11 - EMPTY
C12 - CKP M grnd || B16 - CKP M grnd
C13 - TDC M grnd || B14 - TDC M grnd
C14 - CYP M grnd || B12 - CYP M grnd
C15 - EMPTY
C16 - PSPSW || B08 - PSPSW
C17 - ALTF || D09 - ALTF
C18 - VSS || B10 - VSS
C19 - EMPTY
C20 - EMPTy
C21 - EMPTY
C22 - EMPTY
C23 - EMPTY
C24 - EMPTY
C25 - EMPTY
C26 - EMPTY
C27 - EMPTY
C28 - EMPTY
C29 - EMPTY
C30 - EMPTY
C31 - EMPTY
D01 - TPS || D11 - TPS
D02 - ECT || D13 - ECT
D03 - MAP || D17 - MAP
D04 - VCC1 MAP || D19 - VCC1 MAP
D05 - BKSW || D02 - BKSW
D06 - KS || D03 - KS
D07 - PH02S || D14 - PH02S
D08 - IAT || D15 - IAT
D09 - EMPTY
D10 - VCC2 || D20 - VCC2
D11 - SG2 || D22 - SG2
D12 - SG1 || D21 - SG1
D13 - EMPTY
D14 - EMPTY
D15 - EMPTY
D16 - ELD || D10 - ELD
So A C and D are the plugs, the number represents the Pins
So A01 is injector 4, this runs to the ob1 side of the jumper and connects to pin A02
HUGE thanks to Neal for helping me with this!
heres the completed harness
On the harness that plugs into this jumper (OBD1 side) i need to add ALT Control, Primary O2 sensor and VTAKZoR which connect to the 3 pins next to my thumb
Last night i carried on with some wiring making the rear harness have the factory fuel pump wiring in place and pinned it into the oem plug - no splicing all oemness
some mess from stripping a FI rear harness
added to the existing rear harness
and heres a pic of the dash in place
OBD-2a || OBD-1
A05 - EMPTY
A07 - EMPTY
A13 - EMPTY
A14 - EMPTY
A15 - EMPTY
A21 - EMPTY
A25 - EMPTY
A26 - EMPTY
A28 - EMPTY ||
A29 - EMPTY ||
A30 - EMPTY ||
A31 - EMPTY ||
A32 - EMPTY ||
C01 - EMPTY
C09 - EMPTY
C11 - EMPTY
C15 - EMPTY
C19 - EMPTY
C20 - EMPTy
C21 - EMPTY
C22 - EMPTY
C23 - EMPTY
C24 - EMPTY
C25 - EMPTY
C26 - EMPTY
C27 - EMPTY
C28 - EMPTY
C29 - EMPTY
C30 - EMPTY
C31 - EMPTY
D09 - EMPTY
D13 - EMPTY
D14 - EMPTY
D15 - EMPTY
- Tue Aug 06, 2013 9:13 am
#335182
That hatch has come along way.How long has it taken you so far
- Tue Aug 06, 2013 10:04 pm
#335201
Blimey you have got on with that quick I started mine January last year and just on paint now but havin mega troubles lol Im not likin the whole paint business. What sort of materials have you used
