- Fri Jan 09, 2015 10:17 am
#350922
Mod List Updated for anyone interested in reading. =)
Engine:
96 USDM GSR B18C
AEM Tru-Time Cam Gears
Integra Type R Valvesprings & Seals
3-Way Port & Polish
Gates Racing Timing Belt
NGK Heat Range 7 Spark Plugs
MSD Wires
Drop Engineering Motor Mounts
Drop Engineering Transmission Mount
Painted Valve Cover
Billet Aluminum Oil Filler Cap
K&N Valve Cover Breather Filter
Mobil 1 5W30 Full Synthetic Oil
Integra Type R DC2 Intake Manifold
AEM Black Series Fuel Rail
Hondata Intake Gasket
B&M Fuel Pressure Controller & Gauge
Hondata Metal Plate Head Gasket
Wiseco Low Compression 81mm 8.9:1 Pistons
ACL Race Bearings
Eagle Connecting Rods
Supertech Block Guard
Type R Crankshaft
Transmission:
Integra Type R DC2 LSD S80 Transmission
ACT Heavy Duty Pressure Plate
ACT Stage 2 Clutch
TCC-R Shortshifter
TCC-R Lightened Flywheel
Mobil 1 LSD Oil
Turbo Kit:
CT26 Toyota Supra Turbo
- CNC'd CT26 to T3 Adaptor Plate
- CNC'd Exhaust Outlet Flange
- 2.5" V-Band Flange & Clamp being welded on the turbo exhaust outlet
- Titanium Heat Blanket
- K&N Slim Air Filter
- 10AN Oil Drain Line & Fittings
- 4AN Oil Feed Line & Fittings
- 4AN Coolant Line & Fittings
FullRace T3 Top Mount Turbo Manifold
- Almost Brand New 2000km Used
Tial 38mm V-Band Wastegate & Custom Welded Dump Tube
- V-Band Clamps on both Wastegate & Dumptube Sides
- Current 7PSI Spring
- Additional 10 PSI Spring
2.5" EBay Downpipe
- Intend to weld V-Band Flange & Clamp to mount to Turbo
- Have to custom make to fit properly still.
Chipped P61 OBD1 ECU
- Chipped with a SST 27SF512 Re-Burnable Chip
- Currently with a P30 Basemap
- All Sensors Working
- Soldered in Zero Force Insertion (ZFI) Socket for easy chip removal
- All Main Capacitors Replaced
- All Professionally Done
BLITZ Super Sound BOV
- Has two outlet attachments, one filter and the other is open
- 2 Springs, One for soft and both for hard
- Brand New
- Missing Vacuum Line
EBay Intercooler
- Painted Flat Black
2.5" Charge Piping
- Professionally PowderCoated Black
Stage 1 Snow Performance Methanol Injection Kit
- Switched Solenoid to shut off
- Brand New In Box
440cc DSM Injectors
- Pigtails Included
52mm Prosport Evo Digital Boost Gauge
- With Sending Unit
Miscellaneous Parts
- VMS Mechanical Liquid Filled Fuel Pressure Gauge
- NGK 7 Heat Range Spark Plugs
- Oil Pressure Sending Adaptor for Oil Feed to Turbo
- 10ft of 4AN Stainless Steel Line
- 3ft of 10AN Stainless Steel Line
- Titanium Heat Wrap for Downpipe
- Weldable Bung for Oil Pan
- 2 Weldable Bungs for Downpipe, O2 and Wideband
Engine Bay:
Russel Black AN Inline Fuel Filter Kit
SS Braided Clutch Line (Master to Slave)
Black AN Power Steering Delete Loop Kit
To Order:S2000 Clutch Master Kit
Battery Relocation Kit
Fuse Box Relocation
Engine Harness Tuck
Headlight Harness Tuck
Shaved & Welded Engine Bay
Carbon Fibre Hood Struts
Body:
To Order:VIS Carbon Fibre Hood
To Order:BYS Carbon Fibre Front Lip
To Order:BYS Carbon Fibre Spoiler
To Order:VIS Carbon Fibre Hatch
Retrofit D2S Morimoto Bixenon Headlights.
Phillips D2S 85122+ 4300K HID
JDM Fog Lights
H3 3000K HID
Blacked-Out Taillights (For Now)
Front & Rear EGR Racing Tow Hooks
Antenna Delete
Hood Pins
Wheels & Tires:
To Order: 16X8 Avid.1 AV-05 (BBS Reps)
To Order: Toyo Proxes R1R 185/45R16
To Order: BWR Open End Lug Nuts
To Order: ARP Extended Wheel Studs
Suspension:
Full 96 Spec Type R 4x114.3 Disk Conversion Kit
To Order: Function & Form Type 2 Coilovers (10kg Front & 8kg Rear)
Energy Suspensions PU Bushings Master Kit
Mugen Front Upper Strut Bar
Type R Rear Strut Bar
Type R C-Pillar Bar
GODSPEED Front Upper Control Arms
GODSPEED Rear LCA's
GODSPEED Rear Camber Kit
Aluminum Rear Subframe Brace
Aluminum Lower Tie Bar
24mm Progressive Rear Sway Bar
Exhaust:
Apexi N1 2.5" Catback
Cat Delete
Interior:
De-Branded FRP Bucket Race Seats
3 Pod A-Pillar Gauge Holder
ADD W1 52mm Digital Oil Pressure Gauge
ADD W1 52mm Digital Oil Temp Gauge
ADD W1 52mm Digital Boost Gauge
ADD W1 52mm Digital Water Temp Gauge
ADD W1 52mm Digital Air/Fuel Gauge
11" Rally Steering Wheel
NRG Black Short Hub Adaptor
NRG Black V2.0 Quick Release
Carbon Fiber Shift Knob
Black & Red Stitch Shift Boot
AutoPower 6-Point Weld-In Roll Cage
Rear Interior Removed
5 Panel Wink Mirror
Stereo & All Wiring Removed.
Rear Wire Tuck
