#293973 Lets us know how that combo works out with the R.C.A's and the Hard Race Super Tie Rods!! I am very interested in knowing. This was something I also wanted to try out.
I plan on getting the Hardrace FLCA's, cause when I did my suspension I only changed two Front lower control arm bushings. And now two are shot.I am going the easy route and just getting the two flca's.
Nice new parts you got built up there!! Can't wait! :thumb:
By jdmTK
#294021 Ill for sure let you know. I can finally get back to working on the car cause we were finishing the ceiling on the garage and putting new lights in and just finished last weekend so the garage is slowly getting back to normal and I can get back to work.
jdmTK wrote:Ill for sure let you know. I can finally get back to working on the car cause we were finishing the ceiling on the garage and putting new lights in and just finished last weekend so the garage is slowly getting back to normal and I can get back to work.
:thumb:
By jdmTK
#294281 got the quick release installed and the rsx seats.
the seats are gonna take some modification to the brackets to make them bolt to all 4s but they look pretty good all mocked up
By jdmTK
#294283 and my lil bro had his camera in the garage taking some pics.
some pw:jdm washers and smashed strut tower
hardrace tie rod ends sort of installed. haha
morning fresh and RSXs
https://www.facebook.com/pages/Ez-Films/226588267412501
check his page out on facebook
By jdmTK
#295802 did a little more work last night.
re did the break lines in an attempt to make them look a litle more less noticeable, kinda screwed up the one that goes to the passenger front so im going to re-do that one.
BEFORE
AFTER
also got the gauges in and working on wiring them.
and i picked up a different, smaller, and brand name turbo from a buddy.
Garrett t25.
just a little bit smaller... lol
By jdmTK
#295936 finshed wiring up the gauges last night, just some buttoning up to do but otherwise theyre all wired up.
mounted the wideband box under the dash.
and all lit up
next up in finding a good spot to mount the fusebox from under the hood in the dash
By b20_link
#296604
Jr_DSantos wrote:Great Progress :thumb:
word!! nice on the Progress man :thumb:
all i have to say is ///been there did that !
it feels good it is all done and you driving it !!
trust me :thumb: :thumb:
By jdmTK
#297541 finally got around to cutting the carbon hood and installing the aerocatches!
just masking off to draw the templates out
cut holes... had to cut the under side verryyy carefully to fit the PW:JDM backing plates i got.
installed! you can also see where i cut out the fog light holes for the IC piping.
opened
flush
UPDATE:
pistons and rods are being media blasted and hot tanked along with the crank, oil pan, oil pickup, and lower baffle are being hot tanked and once thats all back motor assembly can begin
ALSO
planning to order function and form type 1 coil overs and a cometic 5 layer head gasket soon.
By jdmTK
#298377 got some more work done.
had Dimension Autoworkz soda blast and hot tank some parts.
and got that crank
also got the BYS on, proably gonna need some adjusting but it looks pretty good
also tore into my RSX leathers and found that they were proably layin in a junkyard for awhile at one point or another
and last night i got the water pump and tensioner on the block along with the oil pan studs and the freeze plugs
By hondakid
#298770 Let us know how those coilovers are im debating between those or tein basis
