- Wed Aug 26, 2009 11:25 am
#139859
Thanks teal. Not dynod yet... waiting for a new map sensor because the one i had doesnt work. Just street tuned at the mo at low boost. 8psi max. Still pulls really gud. I was thinking about the clamps.... do you think zip ties will hold it? im gunna be running about 16psi i think
- Wed Oct 14, 2009 9:54 pm
#150765
Heres my full spec...
Vitara pistons
Eagle rods
Crower stage 2 Turbo cams, Titanium springs and retainers
ACL race bearings
Tial 38mm wastgate .9bar spring
Stainless 3.5" downpipe, 2.5" de-catted exhaust
.50 trim Turbocharger
Apexi power intake filter
2.5" charge pipes
fmic
Relocated oil filter and cooler system
ACT 6 puck clutch rated 285Lbs/ft
Fidanza 7.5lb flywheel
3bar omnipower map sensor
Hondata S300
650cc RC engineering injectors
walbro 255 fuel pump
Adjustable fpr
Racing aluminium radiator
NGK iridium plugs
10mm high performance ht leads
Here are the dyno results...
7 Psi Runs...
12 Psi Run...
