- Fri Mar 27, 2009 5:26 am
#106071
Thnx people
Mordiiax wrote:Where did you mount the 4p harness? Do you still have the 3p in use?
I also have the complete Sparco setup (regular Evo chair though) and i think it builds a bit to high, i want to sit lower. What do you think about that?
I mounted the 4 point harness to the stock holes from the back seat.
When you remove the back seat, you will see 2 screw holes on the left and right side, so 4 in total. 2 are from the old back seat belt, and the other 2, i dont know. but they are there.
That is for the shoulder belts.
For the lower belts, you got to use the hole from the slide of the stock 3p harness on (driver side) left side. The right side, you have to drill, or use the extra mount that is mounted on most aftermarket floor seat mounts.
I dont know if you unerstand what i told you, if you want i can make some photos of thise mount points
Civic-eg PANDA CREW!
Dutch Champion Karts 2007
www.rosracing.com
