- Mon Aug 03, 2015 8:46 am
#355137
Still can't post up multiple pictures. Guess my post counts will go up then.
- Mon Aug 03, 2015 8:56 am
#355141
Inside interior firewall sound deadened and other side of it has a nice reflective aluminum/ fiberglass heat shield to keep heat inside of ummmm TRUNK ENGINE BAY. Guess I'll call it that. Going to be a tight fit for passengers but main reason I want to put rear seats into my eg is to make it not look so suspicious of a monster in my trunk for them poe-poes. My whole firewall is easily removeable with simple bolt offs in just about 2 minutes in case I ever needed to access anything or swap out engine. Makes for a very maintenance friendly mid engine.
- Mon Aug 03, 2015 9:01 am
#355143
Almost all covered up in this picture. U might ask why there is a cut out for the intake manifold.before I had the engine setup with no provision for rear seats. But now that rear seats are going in I had to relocate my engine 2" back design a new turbo manifold. More on that in the future. But guess it'll be an easy access for me to easily recalibrate my tps sensor. Worked out for the best
- Mon Aug 03, 2015 9:04 am
#355144
Sorry for bad quality pictures guys and gals. Only got a smart phone to use so yeah. gas tank is a bit dirty so don't mind it. Needs a tie down bracket for that gas tank. Possibly looking forward to building my own aluminum tank to fit at least 10 gallons and reshaped in case of front end collisions. Thats just a few hundred $$$ away for nice spool gun, argon tank and aluminum welding wire. Sponsors accepted hahah. hope that mishimoto radiator that I got off Craigslist for a 5.0 mustang don't make my car weaker due to domestic reasons.
In this picture u can also see my temporary throttle mock up cable. Will definitely need to work on that one of these days.
- Mon Aug 03, 2015 9:19 am
#355149
Like they say "FIRST THE WORST, SECOND THE BEST". Left one was the step child and right one is well I guess the better of the two step children. They both won't be used on my real turbo manifold. Guess third time will be the charm or maybe I just like to waste time, welding gas, welding wire, and pipes.
- Mon Aug 03, 2015 9:22 am
#355150
My temporary turbo manifold. Actually its not even temporary its just a prototype. With a build like this u sometimes just have to build and rebuild because so many things come up especially if u want to design a manifold that'll give good flow and allow for back seats. Why do I have to try and do the impossible sometimes. Oh well It'll be worth it in the end I hope
- Page 2 of 3
- 1
- 2
- 3
