- Sat Dec 04, 2010 3:48 pm
#225938
that is the cheapest way
- Sun Dec 12, 2010 2:47 am
#227420
What type of bulbs is there inside the climate control buttons etc?
Daniel Nilssen - My D16Z6 EJ2 94' <- (Click Website)
Member of following clubs:
Club Honda Norway - Supporting Member
Detailers Club Norway - VIP member
D-Series.org - Premium Member
- Thu Dec 16, 2010 4:45 am
#228217
Hey I just did this diy check it out.
I went with some of these
they are T5 5050 LED SMD I was thinking that they would spread the light out nice
I just did the cluster for now to see if I liked the color and how they spread the light.
Sorry no before pics kinda forgot till I was about 3/4 the way through
Now for the shitty part put them in got all them in the right way so they would light then looked at them for a bit
30 mins later decided to take the hatch instead of the truck to my daughters basketball practice. She is 7 even said I like your lights why are they blue. We get there I tell her make sure you lock the door. She gets out and closes the door and don't ask me how she does it but she shuts just the tip of her thumb in the door. Just trapping it in the little gap between the door and the body.the door was locked so I had to unlock the door and open it to set her free. So if that isn't bad enough get into the car to race home and turn on the lights and no dash lights. I think great turn the switch off and back on just the left side lights up. I think WTF??? then they start to all slowly turn on then they all go out and so does the climate control lights I figure ok its just a fuse and oh well not to far home I will drive home without dash lights. Then I start to smell burnt plastic son of a bitch is this car gonna burn up??? race home no smoke and the smell starts to go away. I took care of my daughter and went out to dig into the hatch. All the fuses are good pull back out the cluster and what do I find...
shitty ass light I wonder why the fuse didn't blow???
and my daughters thumb is ok a little swollen and all purple under the nail but about 1 and a half hours after she says is practice over or can we go to the end of it?
- Thu Dec 16, 2010 6:02 am
#228228
how did u make all the other buttons like up next to the steeringwheel the only button that lights up for my car is the rear defroster
TEAM OUTKAST since AUG 2007
NORCALTUNERS.COM
CIVIC-EG.COM
NORCALTUNERS.COM
CIVIC-EG.COM
- Thu Dec 16, 2010 6:13 am
#228234
If you asking me all I have in my car is the rear defrost switch and I haven't gotten LEDs to put into it or the climate controls I think that I am going to get white ones to put in the cluster not sure if I like the blue.
- Thu Dec 16, 2010 5:25 pm
#228328
Hey just wondering if anyone knows if it is safe to just plug another light in place of the one that had a meltdown??
- Thu Dec 16, 2010 7:10 pm
#228346
I would first check if have problems with the grounding (if that's what they call it in english).
- Fri Dec 17, 2010 1:18 am
#228412
Looked over everything and everything looks normal. Not sure where to check if the dash lights are grounded out. So grabbed a extinguisher and put a bulb in and no lights. It has a good fuse in it. What I am wondering is if the wires can burn up and the bulb at the same time?
- Sat Dec 18, 2010 7:08 am
#228604
Don't you ever put in a bigger fuse than you're supposed to!
That may catch fire. And you don't want your wiring to burn. An expensive fix. There must be a grounding fault somewhere.
- Sat Dec 18, 2010 12:18 pm
#228612
http://www.superbrightleds.com/cgi-bin/ ... 74_t15.htm
These work best in my opinion, they won't break off or move when plugged in.
As said earlier in the thread you may need to razor blade some parts off to fit em, but I just put em in and they work perfectly.
I HIGHLY RECOMMEND BUYING BULBS WITH THE PLUGS. MOST OF OUR CLUSTER PLUGS (WHERE THE BULB IS INSERTED INTO) ARE WORN OUT AND DON'T HOLD THE BULBS IN WELL.
Also, the link to the Climate Control thread is dead. I still can't figure out how to swap my Climate Control bulbs there's a thread on HT but it's just NOT specific enough.
AND last but not least, BUY THE HIGH POWER BULBS. IT MAKES A HUGE DIFFERENCE AND ARE MUCH BRIGHTER THAN REGULAR ONES.
JohnAWESOME wrote:Hey I just did this diy check it out.
- Sun Dec 19, 2010 11:19 pm
#228800
can sumone please post a link to where the bulbs you need are, i cant seem to find them lol
- Thu Dec 23, 2010 7:39 am
#229441
wow im such a douche HAHA soz
