- Fri Oct 17, 2008 1:08 am
#74612
well first you will need the ek cluster
Id suggest an extra guage trim bezel (plastic black peice around the cluster)
The wire plugs that go into the back of the cluster clipped long so as to wire into the eg harness
you will need to get a wireing diagram there is a thread i remember i think i posted a link to one showing the wires what they are for etc....
And you will probaly need a hour to prepare and a hour and ahalf to cut and splice and then it may take you awhile to get the trim bezel to fit correctly since you will need to trim quite a bit off of the top for it to fit.
But yea if you have any questions since I have done this before Just ask but yea never really finished it since in order for it to look real good you will need to customize the bezel with a fill in peice on the bottom since the ek cluster curves the opp. of the eg cluster.
1980 volvo 242
2001 crv
