- Fri Jul 25, 2008 12:45 pm
#63347
i had a guy ask the same question on my loacl forum about an SO4 cluster into the SR4.
it can be done by taking the clusters apart and modding them to fit into the SR4(95) cluster housing. but then im not sure if it will work coz the ECU will read them diff and the wiring might not be the same so over all. much more work then its worth. but check out the diy i did.
the great thing is cause the face i gave is white you can photoshop it to how ever you want it.
Swich: the sound i make as i pass your slow ass
Slow but still in front of you.
Speed Kills...Be Careful...Drive an EG
![Image](http://i92.photobucket.com/albums/l27/wiggly_toe/sigciviceg.png)
