- Sat May 07, 2011 2:31 pm
#254138
I researched and have read conflicting things. Are the front seats straight bolt on without rail modification? Looking into buying some for cheap. I dont mind doing a rail swap but I just wanted to know ahead of time. Also, anyone know if they sit high in an EG Sedan. Its the front only. Any info appreciated. Thanks
anyhow as long as its a integra of model years 94-00 i think they ended in 2000 but anyhow they will work if bought from a coupe the rails will be longer but you should have no problems swapping the rails with your old eg seats.
be careful of the da seats 90-93 however....they look similar but.those will in turn be a pain in the rear to fit completely different and youd have to tear the seats down and switch the seat pans in order for them to work properly.....
1980 volvo 242
2001 crv
2001 crv
