By Classiccarsrule85 - Sun Feb 28, 2010 6:39 pm
#178352
Ok so before i do my DIY thread i want to post this build thread so you can se the progression and the steps then ill do a quick diy for those who want an overveiw...
So lets begin
Why am i doing this?
well ive been back and forth with the dx cluster, si/ex cluster and i even tested out a integra cluster and well i got bored of them all.....and they where not a 100% of what i truely wanted if you will....
So far ive figured out sort of what guages i wish to use
-integra speedo
-Jaguar xj6 fuel guage--tested and works better than stock--
-oem temp guage may try and find a aftermarket one...
-autometer oil PSI guage
-volvo 240 tach(the small tach in its own guage tube)
Ok the guages may be revised as i go but heres some pictures of my progress.....
ok so at this point i was haveing troubles with perfect fitment so i decided to go ahead and section the cluster apart....this was probaly the best decision i made because it allowed me to completely pop apart the clusters unneeded plastic....and here are some pictures......
I then tok the outer frame for teh stock cluster and placed it on the faceplate peice by peice making sure it fit nicely....Then hot glued the thing together waited for it to dry and then took it apart again for a bit more trimming....
I was thinking about useing the srs as a vtec or warning light however i decided to just say screw it and cut that off as well....
And before i cut the front faceplate...(much like the integra swap)
And thus far thats where im at right now as i started many other projects this one is on the back burner for just now i mean im going to definately get to it shortly just waiting on a couple parts in the mail for my swap for the oil psi guage to work.....
Wireing plans....
-I am thinkin of taking the engine harness plugs that im going to get out of the junkyard and use that insteead of wiring the guage directly this will make it easier to accomplish a clean working cluster i think....
So yea what do you guys think and any suggestion on what i should use for the faceplate and baccking plate?? im thinking of useing fiberglass but unsure.....
So lets begin
-integra speedo
Wireing plans....
Last edited by Classiccarsrule85 on Tue Oct 12, 2010 6:10 am, edited 1 time in total.
1980 volvo 242
2001 crv
2001 crv
