- Wed Dec 08, 2010 1:33 am
#226557
ok for sometime now ive had the ek cup holder in my car well not to long ago i found the ek arm rest at a junk yard so i picked it up
ok soo alot of people ask does it fit and what not the answer is YES
ok now this is the part where i tell you, if you fuck up then thats your fault not mine
ok 1st you need some tools/parts
*phillups head screw driver
*dremal or some sort of cutting tool
*self tapping metal screws
*drill wit something to screw the self tapping's in(my case was a 8mm)
*some sort of 'L' brakets
*brakets from ek
*drill bit
*sharpie
Ok lets start by taking out the Eg center console
unscrew the 10 phillups(no pics cuz the ek console is already in the car lol)
but it should look something like this
now this part(already cut no pics of cutting)
should look somthing like this, use the ek cupholder and test fit it to determine where to cut
now reinstall it
now you need to make 'L' brackets or buy them, i made some, you need 2
take out out the cup holder its self and put the console in place and take the L brakets and mock them up in place then remove the console and screw the self tapping metal screw in place wit the L braket, do this for both sides
now after the brakets are screwed into place take the sharipe and mark on the inside of the console where the hole is on the L braket
then drill a hole on both sides and then screw in the ek cup holder
now for the ek arm rest your gonna use the og screw thingys for the ek arm rest
mock up the arm rest and figure out where to drill the holes for the screws
and then put it in place and screw it in
and then there is this "U" braket you need from the EK as well, ill post more pics on that later it got to dark :/
but when all said and done it should look like this
dont mind the big hole i bought the arm rest from the junk yard for 7 bucks and it was cut right there so im not worried its gonna fixed later but for 7$ i couldnt pass up.
the ash tray and the cig lighter is all functionable aswell
well enjoy your ek console in your EG the cup holders are the best IMO
it holds my arizona teas and the big drinks from taco bell micky ds nd shit like that
**** ill post more pics on that U braket as soon as i find it***
*brakets from ek
*drill bit
*sharpie
now reinstall it
