- Thu Jan 25, 2007 3:27 am
#1692
i need help wit changin out my auto tranny for a manuel one.. i got all the parts n everything that i need... but i got no clue where to start. .i have an idea of wut needs to be done.. but ne information and links will be helpful. especially if ne of u guys have a step by step process of wut needs to be done.. thanks in advance
Definitely have a manual handy, below are the cliff notes.
First be sure you have EVERYTHING... (there's a lot of misc stuff)
Linkage, shifter, manual ecu, shifter bushings, manual rear motor mount, auto to manual conversion passenger motor mount, lower front tranny mount bracket, manual axles, clutch, flywheel, flywheel bolts, manual pedal set, manual throttle cable, clutch master & slave cylinder, clutch lines, manual starter, clutch shield cover thingy (goes over hole on bottom of tranny, spring pin (to connect linkage to tranny aka bitch pin), manual engine harness, ex/si cluster w/ tach (optional), you can keep your radiator, just cap the lines where the tranny fluid used to go.
Start by removing axles/engine, exhaust. Pull the tranny, replace the torque converter & auto flywheel with manual flywheel & cutch assembly. Use Manual flywheel bolts! Replace the throwout bearing while you're at it. Install slave cylinder. Then remove the auto shifter, cable, and pedals (these are a pain in the ass!) Remove the small blue box where the clutch pedal will go. Install master cyl and clutch pedal. Install clutch lines (hard and soft, or buy a stainless braided line) Install the manual gas/brake pedal set too, the auto brake pedal is too wide.
Rip out the auto shifter & cable. (bolts will probably be rusted- get your drill ready) Seal the hole closer to the firewall where the cable used to go through. Drill 2 holes to install your manual shifter assembly (the 2 holes are for the shifter bushing bolts).
Install engine/tranny after installing manual starter & manual wiring harness (92 harnesses don't have the MAP sensor, so if your car is 92, use a manual harness from a 92. If it is 93-95, use a 93-95 harness). Install the mounts. Hook everything back up Connect shifter linkage with spring pin. Install manual axles. Add all fluids (coolant, oil, tranny, clutch + bleed lines) Connect all vaccum lines + sensors.
Wiring:
On the plug for the auto shifter assembly, there are 2 really thick wires. These need to be wired to the clutch pedal sensor so that you will have to push your clutch in to start your car. Or you can just connect these 2 wires together but be sure your car is in neutral every time you turn the key.
Then there is a black wire you will need to connect to a green wire with a white stripe. This puts the car in ?park? so you can take the key out. Now you can also hook this up to the other switch on the clutch pedal, but remember everytime you want to take your key out, you have to press the clutch. And be sure your key is out of the car when you do the swap or your key will be locked in the ignition (i've been told- not sure about that).
Finally, you need to find out what plug you used on the engine wiring harness to hook up to your reverse sensor on the manual transmission.
Find out what colors they are, and find the colors on one of the ECU plugs. You should find it at the ECU plug that has all of the auto tranny sensors. A multimeter helps a lot because there are multiple colors.
Run these two wires to the yellow wire and a green wire with black stripe at the big plug that you cut off from the auto shifter. Now your reverse lights should work.
Don't forget to plug in your manual ECU.
Here's the text version, Overtime I'll be adding more with pics as I take them during my swap...
