- Thu Apr 24, 2008 12:40 am
#52335
And by cutting the handle shorter you are not changing anything. The shorter shift is an illusion, the shift linkage and everything still moves the same distance. the only thing that has changed is your hand sits lower. Clearly you can see by the images above a shifter with a higher pivot point reduces travel.
How is it an illusion?
The reduced throw is measurable, so I can prove it.
You're saying that with a lowered handle the shift linkage moves the same distance as with a normal stock one, and that is true.
But what I get from your post is that you're saying a shortshifter will actually change that distance, wich is not true, it's not even possible;
increasing travel will push the linkage through the tranny or pull it out, decreasing it means you're not getting it in gear with a shorter throw EVER.
I have to admit that a shortened stock won't reduce throw as much as a regular aftermarket would, but compared to stock, it does considerably.
I'll explain it again, but differently;
When you look at pic number 1, this is the situation;
shortened stock and short shifter both have the same distance to travel to get into gear.
Distances Y and Z are exactly the same, as is the position of pivoting point X.
You can clearly see that lowering the connection point of the shifter to the linkage (by putting the pivoting point higher up the shifter) reduces throw compared to stock, and this is how a regular aftermarket shortshifter works, to here, we agree on each other.
In pic number 2 you can see a stock shifter, and this is were we disagree.
As you can see, distance B is shorter then distance A.
Pivoting point X is not going anywhere and distance Z is not changing either.
Effectively, lowering the handle reduces throw, but requires more of your strength to move the linkage, as the leverage has decreased.
The regular aftermarket shortshifter decreases leverage as well, by placing the linkage lower under the pivoting point and slightly lowering the handle.
So a shortened stock shifter does EXACTLY the same thing as a 50 or more dollar regular aftermarket shortshifter, only it's smaller and way cheaper.
Plus I prefer steel over aluminum for shifters.
I'd like to know how you think about what I just said, does it make sense, or am I wrong.
If I am wrong, let me know were I slipped up, because as I see it now, I'm 100% sure I'm right.
