- Tue Aug 06, 2013 4:02 am
#335172
So i just did a clutch change in my gsr. I got everything back together and noticed that the shift fork was very lose. I bled the clutch with no success. the fork has no pressure back towards the slave, and you can move it freely the whole way. I have replaced the throw out bearing. I made sure the spring and ball on the throw out bearing was seating correctly. I changed the pressure plate. I even changed the clutch to a different one. I have tried everything i know to try. I need some ideas so i can get this thing back on the road. if the car is off, it will run through all the gears. if you start it in first, it will take off.
