- Wed Jul 02, 2014 2:33 pm
#346922
Ok I need some help guys and gals....neways hello, I have a leak as the title says and don't know where its coming from. I've got a 94 gsr swap in my eg just incase someone's wondering. I've replaced both axle seals, shiftrod seal and even took the housing apart to clean out and reseal.....am I missing something ....oh and btw its not my oil pan seal leaking cause I've just replaced that with an OEM gasket torqued to spec, sequence, blah...blah..and so forth....pls someone help! Thx...
- Wed Jul 02, 2014 2:59 pm
#346923
Help us out with a few more details.
Is it leaking engine oil, or gear oil?
what area is leaking?
what is covered in oil?
Sometimes if I can't find the leak, i'll spray the area clean and put leak trace powder on it (if you have some, I know it's hard to find) and then drive it to see where fresh oil comes out of.
