- Sat Mar 22, 2014 11:36 am
#343639
ok so i have decided not to turbo my car for the fact that i think i can be more reliable with a mild head build. so i talked to my local shop and they give me a basic list
.cams
.cam gears
.valve springs retainers
.pro series intake
. 65-68 mm tb
.clone big tube header
i have not purchased anything yet cause the actual mechanic who will install the cams cam gears valve springs and retainers said to do some research and figure out the best cams i could get for my stock bottom end. and i am wanting a matching set from crower but i am unsure what lift and a few other specs i can run with the stock bottom end.
also the hp i was told that could be acheived was around 200 on this build is that a possible number?
.cams
.cam gears
.pro series intake
. 65-68 mm tb
bomb green hatch club
