- Sat Apr 27, 2013 2:57 am
#331054
Im going to build a minime but not sure of pistons. Which pistons should I go with? I want high compression and im using d15b7 block and d16z6 head. Going to build from ground up.
- Wed May 01, 2013 6:17 pm
#331227
Depends how high of compression u want. Is the car a daily or track car. And available octane grade makes a little difference also.
Look at zealautowerks.net select D series and play with ur options will give u a good idea of where to start.
