- Wed Oct 06, 2010 10:50 am
#217103
poorman type-r wrote:From experience its better to build all at once then build piece by piece, but its on you bro whatever you do, good luck
as for mine and AutoX debate its no worries im not argueing just trying to prove my point.
Agreed if you are going to go piece by piece it's best to acquire all the pieces and do it all at once than to add each piece individually, especially if you are going to do a built motor.
I wasn't saying you were wrong ... and I'm also aware that you can get more horsepower from a simple turbo build than from a simple N/A build (which is why I went turbo D, instead of N/A B).
Seriously OP don't worry you haven't caused any trouble, no one here is getting there panties all bunched up.
Anyway ... yes you can get 200 hp more easily with a turbo. That wasn't the point I was arguing I was simply pointing the OP in the right direction for a 200+ whp N/A Non-VTEC build (since I have done a lot of leg work on this set up already). The setup I mentioned can be run on 92 octane 11:1 is easy on 92 (and with that setup can get you into the 200 whp range) ... when you start getting into the 13+:1 it get's problematic. There's at least one person I know of who has managed to run 12.5:1 on 87 octane (with no detonation). So it's all in the ability of your tuner.
I know that seems unbelievable so here's a
link to prove it.
I totally agree this is a VERY expensive setup, but the OP asked for N/A power ... so I pointed him in that direction.
OP if you want cheap power ... go FI. If you want something fun and reliable see if you can't find a B series supercharger kit (I think you can fine the JRSC units still). Or get a smallish turbo charger (like a bigger t3, or a t28) that will spool quickly, those are a lot of fun on the street.
Ultimately it's up to you, how much patience you have (i.e. how long you are willing to save to get the parts before you NEED the power), how confident you are in your tuner (or your own tuning abilities) and your preference of power adder.
Straight lines are for sissies.
