By KRYSTED9354
#51520 ok i checked the haynes manual and im looking to turn up my idle because its dying out when gets warm and idles at like 200 , so i wanted to turn it up and theres like 3 ways, wondering
how have u guys turned up your rpm the easiest way ? i know theres like an idle screw on the throttel body ? what does that do i turned it and nothing ?? thanks
#51524 :lol: why do you want to turn up your idle?
By KRYSTED9354
#51525 :roll: because its dying out DUH !!! my engine was redone and the idle is to low, why else ? LOL
#51526 Sounds like your engine is starved of air, flat beat. Factory idle is fine.
By KRYSTED9354
#51527 dude if u cant answer question then dont bother, and 2 my car is fresh built 160 horse sohc, just finished tuning it yesterday, THANKS
By id3379
#51533 use the idle screw on the throttle body, if that isnt giving you enough for some odd reason then adjust your throttle cable..
:roll:
By vtec_gloucester
#51544
KRYSTED9354 wrote: just finished tuning it yesterday, THANKS
didnt do a very good job tuning it if it has a shitty idle and dies all the time.
only ways i know off is the screw on the TB and there is an alan key screw on the idle control valve which can adjust the idle.
have you check compression since the build?
also, any air leaks in the vac pipes or trapped air in the coolant system.
By KRYSTED9354
#51547 everything is checked just my line is brand new , and so it wass to loose just fixed it, i had to press down more on thepeddle, now the line is tight !! dont worry im not stupid !! we own a few shops and know what were doing :thumb:
compression checkes and very high !! thanks admin, u can lock this post thanks
By id3379
#51549
KRYSTED9354 wrote:dont worry im not stupid !! we own a few shops and know what were doing :thumb:
:lol:
By asianrob
#51550 may have a vaccum leak i got one on my teg and it dyes everynow and then just to lazy to fix it lol
KRYSTED9354 wrote:dude if u cant answer question then dont bother, and 2 my car is fresh built 160 horse sohc, just finished tuning it yesterday, THANKS
Trying to talk smack back, in none English is not cool. You're pathetic. :lol:
By id3379
#51560 roflcopter :lol:
By LowTEC-Derbo
#51568
id3379 wrote:roflcopter :lol:
gotta do it right!
idle screw on the throttle body will adjust your idle.
chances are your tune is messing up your idle. Double check your Fast Idle valve.
Posting stuff such as:
KRYSTED9354 wrote:because its dying out DUH !!! my engine was redone and the idle is to low, why else ? LOL
Just makes you look like an Douche. It also discredits any respect any of us(or atleast me) had for you. :thumbdown:
#51578 The funniest thing I find is that he likes to throw about his 160HP SOHC in peoples faces, but awhile back, he posted some electric supercharger from eBay, and asked if it was any good.
You're full of smack bro.
