- Wed Jun 26, 2013 1:39 am
#333427
I have a problem with my wheel alignment, my toe is off but I'm not sure which side is the one off. I also bought my car that previously had the steering wheel badly adjusted, so not only is the toe off on my wheel but also my steering wheel isn't straight. Would the alignment shop be able to align my toe/camber and steering wheel? Thanks in advance.
- Wed Jun 26, 2013 2:23 am
#333428
A good alignment shop should be able to adjust all of the above mentioned.
- Wed Jun 26, 2013 10:02 am
#333440
I'm trying to find a way to center the steering wheel where the rack is dead centered so I can adjust the steering wheel. A lot of shops around my area only adjust camber/toe/caster keeping the steering wheel straight. I'm afraid that after the adjustment, my left or right turns will be less or more than the other, it wouldn't be the same.
- Wed Jun 26, 2013 12:56 pm
#333442
Most shops once they adjust everything will center the steering wheel. You could do it yourself by removing the 17mm nut and turn it until it's straight. But it sounds to me like you need an alignment done so just do that
1992 Honda Civic SIR-S
- Wed Jun 26, 2013 8:04 pm
#333452
this and youll be
HeikDiesel wrote: you need an alignment done so just do that
this and youll be
