- Sun Sep 16, 2012 8:56 pm
#315799
does anyone have the problem where your antenna falls down past your plate i notice two metal prongs in there but i cant figure it out my concern right now is water getting in there let me know thanks.
EGRUNNER wrote:does anyone have the problem where your antenna falls down past your plate i notice two metal prongs in there but i cant figure it out my concern right now is water getting in there let me know thanks.
You're antenna has a grounding point right below that plate. It means something broke. Mine snapped off and could be pushed further in like yours. At this point, you should either replace your antenna assembly or remove it and get a block off plate. I personally removed mine and used black RTV silicone to seal it up.
