By Juan Carlos
#315485 You can use Integra back seats as well . I had that same set up in my 95 2 door coupe
By EJ1_MK
#315524 You will have to find a back seat from 4 door teg, the integra 2 door is a hatchback so it has a split rear seat and the civic coupe is a one piece, Now you can use the back seat base from a 2 door teg it takes a bit of extra foam under the seats to make it fit just right.
By Juan Carlos
#315526 Thanks for the help for explaing it better.
By ej1_dohc_vtec
#315536
EJ1_MK wrote:You will have to find a back seat from 4 door teg, the integra 2 door is a hatchback so it has a split rear seat and the civic coupe is a one piece, Now you can use the back seat base from a 2 door teg it takes a bit of extra foam under the seats to make it fit just right.
hey man thanks
