By bradleyg
#313753 Hey guys I'm getting ready to swap out the front hub assembly on my 92 vx with a gsr swap and I was wondering which hub bearing it takes. If any of you know I would appreciate it. I'm getting sick of hearing this womp womp womp noise constantly haha. :thumbdown:
By EJ1_MK
#313755
bradleyg wrote:Hey guys I'm getting ready to swap out the front hub assembly on my 92 vx with a gsr swap and I was wondering which hub bearing it takes. If any of you know I would appreciate it. I'm getting sick of hearing this womp womp womp noise constantly haha. :thumbdown:
Are you swapping the entire spindle assembly? If so you want to get the bearing that goes along with that which should be the same for all Integra models.
#313756 The bearing are different sizes so u will have to use the gsr bearing. And I think there is a difference in size if they came from a abs or non abs..Not sure hope someone else can chime in and help. Here are these two links with pretty good info on brakes.
http://honda-tech.com/showthread.php?p=45884943
http://honda-tech.com/showthread.php?t=3044628
By EJ1_MK
#313758 ^^ just did a search at napa and orielly auto parts and both show the same part number for the front wheel bearing between the LS and the GS-R the only difference in the ABS and non is the centric ring that is on the axle, and the sensor that is bolted to the spindle.
By bradleyg
#313788 Thanks for the help guys. I'm going to get the wheel bearing for the gsr non-abs and hope that's the right one. If not I'll have to take it back and get the other one haha
I just wasn't sure if I use the civic bearing or the gsr bearing. :thumb:
#313791 Glad we could help. :thumb:
