By rak511
#307727 My car is a 93 si hatch... its got moonroof but i have to crank with the handle... i have the motor up there but dont know if its burnt up or wat cuz the guy took the switch out... but the wires r still hooked up and look to run down the pillar like usual... where does this lead to cuz ive been laying under my dash and cant find anything that looks like the thick black wire... i have the switch cuz i just picked it up at the junkyard but dont know where the end of the wire goes... any help appreciated
#307751 2 wires go to the motor, reversing polarity. They normally rest at ground. The switch sends power down one to move in one direction and vice versa.
The wires go to a switch on the dash that you'll need to get because it's a peculiar switch (DPDT switch internally wired for polarity-reversal). That switch has another two wires going to the moon roof relay. One is a shared ground and the other is ignition power.
I wouldn't use the relay. I'd run the power wire to a fused (10a) ignition source ie the under dash ignition option output. The other to a ring terminal to chassis ground. Use 14 gauge stranded wire.
By rak511
#307757 Ya... i pulled the head liner down and seen the 2 wires were plugged into the motor and run down the side pillar thing and then once it gets to the dash i have no clue where it runs... its not in any of the bundles from wat im seeing. I have the switch already in my dash now... just gotta plug it in im pretty sure
By cjw_89
#311604 Maybe someone swapped it to an si but never finished wiring it
