By EJ1STYLEN
#247307 Sup Guys I Was Wondering what size is the hole for the subfram were the rear lower control arm bolt up with the subframe...because i think i crossed threaded it...
By 94EJ2
#247333 you can just snap the welded nut on the back side off and use a diff bolt and nut thats what i had to do if its the same place that were thinking of
By EJ1STYLEN
#247558 how can you snap it of? do i just cut it off with a cutter or some kind of wheel cutter?....
By Ecc0
#247626 Get an old socket that fits onto the welded nuts at the back end of your car then get a big breaker bar on it and give it a right good yanking till pop it'll come off.
By EJ1STYLEN
#247695 oh ok..ill just use a impact gun hehe to make it easier....do you guys know what kind or size bolt to use?
By cjw_89
#247789 you may want to be picky with it. The factory bolts have those ridges in them if your talking about about the bolt on the furthest inside that mounts your lca to the subframe?
By EJ1STYLEN
#247985 yeah im talking about the lca that bolts up to the subframe...can i just use any bolt and nut? or is there a certain size bolt to use? cause i just dont want to snap the nut off and not know what bolt to use...and has anbody done this before? if yeah what size bolt you guys used....cause right now i cant put my ASR Subframe on because of that bolt being stuck there because its stripped....so more info please
