By 92civicEGsedan
#359337 Okay I'm in the process of gutting my car making it into a sleeper it's a 4 door and I've removed the rear seat, carpet, front door panels gonna remove the rears door panels, the sound deadening everything from my trunk, rear seat belts also trying to remove the ac and heater box behind the dash if I could ever figure out how to remove it and I'm also removing the srs and I removed the head liner. I want to know what else I can remove and or cut out I want to get the car as light as possible also going to remove the cruise control if it is not necessary I want to know what it is and if it's removable
#359341 Get a Odyssey PC680 battery. I replaced my heavy battery with one and it weighs about 1/3 less and is the size of a head unit. But get a battery tender if you let the car sit for long periods of time.
By 92civicEGsedan
#359344 I saw your post on weight reduction 6th gear advertising and saw the battery thing if mine wasn't less then a year old I would do it
By TrailerTrash
#359346 if it has power windows and locks, replace the doors with manual ones
take the dash out and just start taking the airbox/ac/heater core stuff out. be sure to loop the heater core hoses from the engine
get solid engine mounts from Innovative or Hasport then remove the torque arms and mounts and that big ass ac compressor bracket
convert the car to manual steering or remove the power steering parts and loop the fluid lines
get light wheels
By brandoff88
#359375 theres a nut in the engine bay that holds the heater core in, its right by the hose inlet/outlet...took me ages to figure out why my heater core wouldn't budge, that's probably the main issue that I can see people having
By 92civicEGsedan
#359476 Right now it's a Garrett gtp38. I'm slowly working on the header and everything and once I get the header built I'm rebuilding my lil d15
By 92civicEGsedan
#359746
TrailerTrash wrote:then dont worry about bracing.
what kinda drivetrain you running?
When I mentioned bracing I was talking about stock bracing I could cut out
By 92civicEGsedan
#359776
HeikDiesel wrote:Car is an auto? Where is that horrendous oil leak coming from?
Yeah but I have a manual waiting for this to start and my valve gasket and from the distributor burned more oil then it leaked so I never paid attention to the leak just made sure my oil level was good it'll get a good cleaning and rebuild about next spring
