By 92EXFrostWhiteEG9
#89760 all right i not sure whats going on today im a little bit confused.....i went to go start my car up to warm up cause i havent been driving it.....so i start it up and after warming up to reg temp i went around the block just cruising when i get back to park in same spot i noticed that the snow is grey and the exhaust is leaking CRAZY gettin evey thing dirty....not to mention my rpm is a little bit below 1,000 rpm.........need help bad or else im walking to work
#89838 Allright ppl need help
By civicnation93
#89913 Leaking what? Gotta be a bit more specific man, when ya say exhaust leak alot of ppl when generally assume your smelling fumes inside ur vehicle, sounds like shit, etc...if its dripping oil / dark substance onto ground? Also hows the exhaust smell, does it do it constantly now, etc. Rpm at idle speed a little under 1k can be normal fyi, the more info ya post the more help ppl can give..
By biretsu89
#89990 hes right.... just a little bit more info is required... the only thing I can think of with the color comming out from the tail pipe is that you car is shitting out carbon... maybe your motor is slowly burning oil and having some carbon build up? for the exhaust leak... check your exhaust manifold.... I have a bad exhaust leak.. but im not running with a donut gasket... bah!
