By 93hatcheg
#82893 ok so i have a b16a in my 93 civic cx and mt v-tec wont kick in! it kist sputters as it tries to engage and disengage :thumbdown: . the only CEL is code 23 for the knock sensor and i have the correct sensor in and my car seems to run fine :? also when i did the swap i bought a 95 civic ex wire harness so i dont have to worry about a wire loose,...right? alll help is greatly appreciated :D
By Classiccarsrule85
#82895 well i think i may be thinking gsr but i think besides the knock sensor there is another thing not on a ex/si harness that you will need to pin into the ecu as well as i think you may need to move a couple of ecu wires around you may have knock sensor and a good one but just may not be in the right spot.....
also I had this very problem in my Cx even bought a si harness but this was for a 1.6l sohc d and still didnt work right but yea id first check your plug n make sure its on there good and besides that i would probaly just look up pin out diagrams n make sure your getting a connection form the inside of the car (ecu plug to the knock sensor wire. you may be shorting out somewhere....
By marvinp8700
#82898 knock sensor is a must for v-tec
ex harness wont have knock sensor
By 93hatcheg
#82907 are you sure a ex harness doesnt have a knock sensor plug cause there is one hanging in the perfect sport that plugs into my knock sensor and the auction on ebay that i bought that harness said it was off a 95 civic ex with v-tec cause i didnt wire in v-tec.
By ej2rey
#82910
93hatcheg wrote:are you sure a ex harness doesnt have a knock sensor plug cause there is one hanging in the perfect sport that plugs into my knock sensor and the auction on ebay that i bought that harness said it was off a 95 civic ex with v-tec cause i didnt wire in v-tec.
92 to 95 EX, SI civics are vtec but they are obd1 vtec harness which doesn't have knock sensor plug bcus obd1 engines don't need a knock sensor.
So you bought an ex harness which its not going to work.
Am guessing you're using a p28 ecu. So what you do is extend the knock sensor wire through the cars chassis or through that original harness loom all the way to the ecu. You are going to connect the extended knock sensor wire to the number 3 hole on the D plug the connects to the ecu.
By 93hatcheg
#82932 ok cool thanks alot man ill definatly try that, just out of curiosity tho is there any plugs on the ex harness that a b16a doesnt have a sensor for?
By ej2rey
#82935
93hatcheg wrote:ok cool thanks alot man ill definatly try that, just out of curiosity tho is there any plugs on the ex harness that a b16a doesnt have a sensor for?
Nah bro all plugs should plug in. You would just add wires for the vtec selenoid, oil pressure switch and knock sensor straight to the ecu and that's it.
By 93hatcheg
#82945 Ok cool man thanks sooo much. I just have one more question tho. If I buy a obd1 gsr harness will I need to wire anything in? Oh and I'm using a virgin p30 ECu
By marvinp8700
#82948
93hatcheg wrote:Ok cool man thanks sooo much. I just have one more question tho. If I buy a obd1 gsr harness will I need to wire anything in? Oh and I'm using a virgin p30 ECu
no
By ej2rey
#82952
No bro you don't need to. You better off with this set up. Its just plug and play. No need for wiring.
By 93hatcheg
#82955 Ok cool so I'm going to order a obd 1 gsr harness then. That is what you ment about thgat setup being best right? Thanks for all the help man I appreciate it.
By ej2rey
#82957 That harness its gonna cost you a pretty penny. I thought you already had the harness.
If you have bank I say buy the gsr harness but if you in a budget I say just wire it up.
But either way good luck.
By 93hatcheg
#82971 Na I don't have bank I just came up on a deal for a gsr obd1 wire harness for 45 bucks :) and I suck at wiring so I don't wanna try to wire my own in.
By ej2rey
#82973 45 bucks???!!
You lucky bastard...
That's coo, then you're set.
By 93hatcheg
#83059 Haha yea I guess I came up pretty good :) but hey thanks so much for all the help :)
