- Wed Oct 05, 2011 1:19 am
#276254
after doing lots of research for hours on end i have found out why they have broken and why they are not bad i have seen people just say there bad but where they cast that broke or are they forged ? because if there cast there gonna break because there rated 500 hp at the flywheel so if you make a lot its gonna break but if you get forged i have read people with ls1 and mustangs with them making 800 plus and no problems at all the common reasons why it brakes
1.builder error
2.you try and build on a budget and don change out other things like your supposed too
3.you run cast on a 500 plus hp build
4.you don't get it balanced(people o that believe it or not)
just take care of your motor
scat cranks are just the same as eagle same material its in the builders hands . its amazing what a little bit of research will do and digging on American muscle forums will tel you!
im gonna give reviews too so don't worry!
1.builder error
#24 COUPE CREW MEMBER
