By EG {FIVE-500} - Thu Aug 18, 2011 8:37 pm
#268022
one day a few months ago. my little civic 1.4 ej9 1997 started having problems starting then about a month ago would not start at all. i would turn the key but no sound what so ever. so i have gone through the list had a voltmeter test done it came back the alternator was reading 12 volts but i explained to the mechanic when i bumped the car i could drive for as long and as far as i wanted so he said it could be the starter motor. so i thought sod it went and baught a starter motor that didnt work so went out the next day and baught a new battery that still didnt work. all the fuses are fine the wires look fine as far as i can see ive changed the earth cables unplugged my sound system in case that is draining it and nothink would work so i got a brand new altenator took it out for a spin come back and now all i am getting from the car is tiny clunk sound from the starter and now to be honest its really
me off i now dont no where to turn i need help
the next route i was going to go down is the ignition switch any one got any valuable information i could use or any ideas on where to look next. i have also checked the ecu to see if every thing is plugged in and everything is plugged in fine on the ecu and behind the fuse board
