- Sat Jan 22, 2011 4:38 am
#234770
Whats up guys i hqve a b7/z6 mini me and i want to squeeze more power. I have i/he the head is stock, i was wondering if i PnP, mill the head (how much to mill?) gasket matching, and stage 2 cams with a base map on the mods that im going to do. I was wondering if i get the base map with all the mods that im going to do will it be safe to run on, On just a base map? And how much hp will i expect. I know if i get a tune i could get more gains. I want you guys opion And help on what to do...
Just becouse a cam is "Stage 2" doesn't mean other brands will be the same. For example a Bisimoto Stage 2 cam will be different then a Skunk 2 stage 2 cam. Dont forget you will want to upgrade your springs and retainers.
Also none of us can guess how much horsepower you will make. Anything we post would be a guess. It depends on your elevation. How good your engine is running, how good(or if a base map, how bad) your Tune is.
2017 Chevy BoltEV DD |2001 Honda CRV SE
