si-b16 wrote:Yep i replaced the fan switch.just couse u replaced the fan switch with a new one dose not mean that the new one is good mite be defective
Don't really want to leave it on all the time, hopefully i can figure out the problem an fix it, otherwise i will have to do what you suggested, thanks heaps you've been a great help
anymore suggestions on how to fix this will be greatly appreciated
so here is what u do take off the plug from the fan switch jump it (make the green wire and the black wire tuch) this will make ur fan run every time u turn ur key 2 the on position. so after u jump the fan swich turn on the car and make sure the fan is runing if its runing start 2 move the wires slowly wile CHECKING IF THE FAN TURNS OFF do this from the fan switch all the way 2 the fan if the fan dose not turn off then u most likely have a bad fan switch. if it dose turn off wile u checking the wire then u have a broken wire
my shit is runing cuz of this forum
14#COUPE CREW MEMBER
my ricer coupe
http://civic-eg.com/viewtopic.php?p=260106#260106
my ricer coupe
