By jred
#206432 B16, B18, H22, B20vtec "frank", LSvtec "frank"
By Carfanatic
#206437 i say B16b.. Gives you a lot of fun :thumb:
#206441 Best engine potential for the same amount of money would be a B18B with a B16 or GSR. Whatever cost savings you make by choosing that engine can be put back into the engine to make it faster than any of the baller swaps.
If you are going to keep the engine near stock with just bolt ons, then the GSR is the best candidate. Also this engine responds to boost like no other, but if you're going to boost the engine you can save a lot of money and get a B18B.
If the cost increase wasn't so huge when stepping up to any of the VTEC motors (not just initial cost but cost of custom swap parts in some cases), then these engines would make a lot more sense.
By jred
#206448 wel im curently doin a B20vtec setup on my 4door eg9 cuz my B16 block got damaged, heard alot of good tings bout this swap but alot of bad tings too..but its the cheapest sub, plus its a 2.0Lvtec ..hope i went the rite route :)
By jayEGR
#206500 :thumb: :thumb: :thumb:
