"do your own thing to stand out... but dont be a noob n be ricerish!
- Fri Jan 08, 2010 11:32 pm
#166993
i beleave a cupcake away! should be 2 bolts and just a quick drain n fill.
- Sat Jan 09, 2010 12:17 am
#167006
its simple if you know what your doing its 3 10mm bolts i mean yea you can just stick with the two but id go with taking all 3 out the third is the harness ground.....
but first you need to take off the radiator hose and intake to get to it..
to give it a rating of difficulty 1-10 10 being hardest id go with a nice 3.5 its simple yet theres parts in the way....
1980 volvo 242
2001 crv
2001 crv
- Mon Jan 11, 2010 8:06 pm
#167643
if you can put on a short ram intake. you can do a thermostat. remember to replace the gasket tho.
