By Benj
#206342 hold up how does not having sparking and the connections to the starter have anything to do with each other?
please elaborate on a few things
a) car is or is not turning over?
b) do you or do you not have spark?
c) when you have the cap off the distributor does the rotor turn?
a few things to check..
a) the 3 main grounds that teal already mentioned. even if the front 2 are good make sure the one that bolts to the tstat make sure it is good
b) if you dont have spark could be, icm (ignitor), change rotor and cap.. check all plug wires, change if the look like crap
c)it the rotor doesnt turn could be a few things, timing belt broke, ( if thats the case i hope this isnt the Z6 you picked up ) , or the shaft broke in the dizzy
well Let us know what happens... Best of luck
By andyc
#206343 Thanks mate, anyone else know what this ecl code is? Im really stuck and have a meet saturday with some civic-eg guys i dont want to miss... Cheers guys :(
By andyc
#206344 Sorry for the repeat posts, im having to do this on my mobile and its fiddly... The engine definetly turns over and the rotor turns too. Ive replaced 2 earths and checked the one on the tstat. Theres definetly no spark. Ive changed the coil and rotor from another dizzy (not new but best i had to troubleshoot with) and still nothing. It used to take a while to start before it died, yesterday with jumper cables it nearly fired up and then nothing again so i left it, im assuming something might have gradually worn?
By andyc
#206364 Where is that?
By Benj
#206376 its in the dizzy
http://www.theautochannel.com/autoparts ... 899lvh.jpg
it would be where that flat part is... try replacing that its only held in by a few screws
By Benj
#206379 umm better pic
http://www.hondacivicrepairs.com/views/ ... r-coil.JPG
its the ignitor unit on the left hand side
By andyc
#206418 I did have another of those and tried changing it out, it wasnt new but surely they both cant be screwed? Thatd be way too unlucky??
By andyc
#206434 I did change it but the one i had to replace it with wasnt new and i hadnt seen it working before but its all i had... The original one is back in so im gonna charge the battery then earth a jumper cable and test for spark from the coil tonight and see what that gives me...
By andyc
#206455 Someone must know what the ecl code means?? Its in a previous post...
By asianrob
#206462 it looks like its throwing a code 10 which is IAT.
By andyc
#206476 Cheers rob, any chance that could stop it sparking??
By Torch_Ind
#206478
ANDYC wrote:Cheers rob, any chance that could stop it sparking??
intake air temp code shouldn't cause no spark
By Benj
#206510
x2...
how did the coil test go??
